Results 1 to 9 of 9
Thread: Repair Labour time. Reasonable?
    Hi Folks
    My 4Motion Diesel Caravelle has 2 oil leaks which I have been quoted to resolve.
    One is to replace the turbo return gasket
    The other is a to replace the fuel pump gasket.
    I realise that both these are in relatively awkward positions but the 19 hours labour I have been quoted does seem a bit excessive, particularly when speaking to the mechanic likely to do the work reckoned 8 hours for the turbo gasket (which he has done previously).
    I can't see the fuel pump gasket taking 11 hours.
    What do you reckon? Reasonable or not?
    John
    Dec 2008
    Sydney/Canberra
    I assume the fuel pump gasket is the one on the end of the cylinder head? If so, they're maybe a 20min job to do.
    As for the turbo gasket, I've not done a 4Motion one, but the ones I have done took around 6 hours. Maybe slightly more for a 4Motion.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Thanks for the reply.
    Not sure of the fuel pump position although I was told it was on the front side of the 2.5 diesel engine.
    Dec 2008
    Sydney/Canberra
    Oh ok, this must be a T4, in which case yes it will be on the front side. Probably only a couple of hours work there.
    '01 Beetle 2.0
    Nov 2014
    IF the mechanic is part of your states Automobile Chamber of Commerce (VACC for us, I guess it is the QACC) then ther is a book with recommended time
    Those times tend to be longer than the could be done in (especially if an expert does it), but they do include cleaning and all that sort of stuff that doesn't add to your job, (but is part of theirs)
    sydney nsw
    jjhobart. what car/engine is it?
    May 2006
    Adelaide South Australia
    In another thread he says he has a T5.
    T5 Engine Oil Leak - most likely source?
    This is probably a good time to remind people to include their model of vehicle & engine when starting a new thread.
    Numerous Mk1 Golf diesels
    Mt Cotton
    [QUOTE=jets;
    This is probably a good time to remind people to include their model of vehicle & engine when starting a new thread.[/QUOTE]
    And also relevant info like year / manual or auto kilometres travelled as each small piece can make keyboard diagnosis easier .
    Jun 2007
    Melb.
    As a comparison on my 2007 T5 2.5L tdi auto I had a new turbo charger installed, Fuel & Vacuum pump and the DPF replaced and was charged 10 hours in total at the start of July. This also included washing the whole engine/transmission and engine bay and it was cleaned so well I actually initially thought they had replaced far more parts then invoiced....and the thing is a rocket...in a van-world type of way.
