Results 1 to 10 of 11
Thread: T5 Transmission
    Aug 2013
    Esperance
    T5 Transmission
    First thank you to everyone on the forum that has helped me before.
    So I am heading to the city next week and planning a transmission service on my 2008 Multivan.
    Is any one on the forum familiar with either West Coast Automatics or Automatic Transmissions R US ?
    still not sure which gear oil to use, just pay for peace of mind and use VW oil or go for the alternative Penrite or Fuchs
    Any suggestions ?
    Incredibly the van has now done 200 000 km on the original factory oil, to the best of my knowledge the box has never been serviced.
    My logic tells me that these infamous transmissions last longer in outback country where 90% of driving is done in top gear ?
    Will post results of service to be done next week.
    Aug 2016
    NSW
    Given that it's been going so well for so long.........it must be tempting to just leave it!
    2018 Crafter Runner
    2012 T5.1 6sp manual.
    2024 Crafter Auto
    Feb 2008
    Adelaide,Oz
    if they're dropping the pan only, it only gets about half the oil out.But it's necessary to drop pan to do filter(a must).
    Check what you're getting.The box holds around 7 litres total
    Steve
    04 T5
    Aug 2013
    Esperance
    Yes opening it up to have a good look and clean and replacing filter and fluid.
    Anybody in Perth ever done business with Transmissions R US or West Coast Automatics ?
    Any thoughts on which oil to use ?
    Aug 2016
    NSW
    I bought ONE litre of manual gearbox oil from VW two weeks ago and it cost me $63!
    2018 Crafter Runner
    2024 Crafter Auto
    Mt Cotton
    The auto fluid is around the same money per litre , I think from memory there was around six litres that our local VW put into ours which lead to its self detonation a few days later . Now this was because they did not bother to remove the sump and replace the filter , so $300 plus for fluid and all it did was flush more dirt and debris into the sump where the new fluid mixed with the sludge in the bottom . That in turn blocked the filter totally and the rest as they say was history . Took me two years to finally get VW to admit that they caused the failure , interesting thing was the next auto the DSG was designed to be serviced every sixty thousand kays and guess where the filter is this time ? yep OUTSIDE the box hmm I wonder why .
    Adelaide hills, SA
    Because it's completely different transmission.
    Mt Cotton
    Yes I acknowledge that it is a different beast but it does show VW probably knew that it was a blunder with the Tiptronic to Seal it For Life and leave a filter inside to block . But what makes the DSG so different still has fluid which will decay with heat and also lose its viscosity due to heat etc. No matter how much spin people put on the VW autos it was still a dumb idea to make it that way . {Yes I still hold a grudge with VW } even after they made amends .
    Adelaide hills, SA
    Wast majority of the tiptronics have the filter inside.
    I know it cost you a lot of money to get your A/T fixed in your T5. However, if the dealer would've tell you, when you had done only 45,000km that you should get the oil and the filter changed, what would you tell him? You would probably react similarly as most people in this thread, and if not you, many others would have. VWA "interim service!"
    That's why many workshops and mechanics keep quiet when they see that some maintenance intervals aren't right. Who needs to get accused and attacked, right?
    Dec 2008
    Sydney/Canberra
    For God's sake.
    We've all been over this with you several times before. 90% of conventional automatic transmissions (yes, that includes the "Tiptronic" in the T5), have the filter inside the sump. There are no conspiracy theories here. Yes, you got the raw end of the deal on a failed transmission, so did a lot of other people. It is not a personal attack on you. These things happen. At some point you will need to accept it, and move on.
