Results 1 to 4 of 4
Thread: Long Coding for ABS
    Aug 2018
    triabunna tasmania
    Long Coding for ABS
    hi,i need some help
    a nfew years ago i did an engine and ecu swap and cluster, on my 2010 transporter
    ever since then i have put up with a fault in the cluster....its a car with squiggly lines going to the wheels(orange)
    i put it down to some sort of incompatability problem and just wore it
    i had an ebay diagnostic cable
    since then i have bought a ross tech hex v-2
    i really want to switch off this symbol
    i have only just joined nthe ross tech forum but cant post as yet(24hrs)
    i think the prob is coding on the ABS page (i ran a diagnostic but the 4 faults were beyond my scope of knowledge)
    is it as simple as changing the long coding? and if so what numbers do i need to enter?
    thanks
    russ
    You might want to start by posting what the actual fault codes are given you have the right diagnostics equipment.
    A full autoscan is best.
    Aug 2018
    triabunna tasmania
    thanks Kamold
    i posted an auto scan to ross tech site but so far no joy
    im going to send the cluster to an instrument repairer and have the light removed...i dont know what else to do
    i need this ESC light to go away
    russ
    Mt Cotton
    Stupid question were the front brakes touched during the transplant , I was wondering if the fault code has been thrown up by a broken or faulty ABS sender at each wheel .
