Welcome to the Forum , it will help by putting up year and model van and also engine type . There are heaps of Techs visiting the site and they will most likely ask that question , to me a non tech it sounds like either a loose or bad electronic connection because in the cooler weather moisture retension in connectors and wiring getting a bit stiffer due to cold could be a problem . My sons T4 did have erratic behaviour with instrumentation and it turned out to be a plug at the rear of the fuse box that was not pushed in properly due to having done a complete engine and then electronics transplant . When it happens have you tried shaking any wiring behind the instrument binnacle or wiring harnesses under the dash or in the engine bay ?
