Results 1 to 10 of 12
Thread: Location of T5 Alternator?
    Oct 2009
    Trying to find the alternator to do a cable upgrade in my T5. Can't seem to find it. Ive located a bosch cylinder looking part that leads to the negative terminal on the battery. Which im assuming is the ground to chassis?
    Where can i find the alternators positive?
    Haven't had much luck finding anything online either.
    Oct 2009
    anyone have a clue?
    Adelaide hills, SA
    Look down under the inlet manifold, close to the gearbox you will see the ribs of the alternator.
    Jul 2010
    Wanneroo, Perth
    Good timing, i was going to do the 'big three upgrade' last weekend and once i had a quick look and couldn't find the alternator i gave up haha,
    Im upgrading mine with 1 gauge cable to help out the stereo and hopefully reduce the amount my lights dim when tunes are played loud.
    Cheers transporter
    2004 VW T5 2.5 TDi SWB
    Oct 2009
    Thanks transporter! Will have another look this weekend when I find some time.
    @ Kevo: Ive seen your build! It's coming up very nicely!
    I'm also wanting to do the big 3 upgrade as my lights dim when my audio hits the big bass!
    If you happen to find the alternator before me, don't forget to take a photo and post it up here
    Oct 2009
    Update: I've located the alternator and the wiring that needs changing. However, I've got no idea how you would be able to remove the alternator - battery positive wire without taking 1/4 of the engine out! It is very hard to get to!
    Adelaide hills, SA
    You may need to clear the area a bit to get to the alternator.
    I'd leave the alternator wire alone and upgrade wires from battery to the circuits that have increased load after whatever modifications you've done - lights, stereo etc. Wire from alternator to the battery is for charging the battery only, you would benefit from bigger diameter wire only if you draw max current from the battery 100% of the time or live in cold climates where temperatures fall below 0 degree C and want to run all your lights and audio at max when the battery is low in capacity due to cold nights, which is unlikely. VW most likely used adequate wire from alternator to the battery.
    Sent from my HTC Desire using Tapatalk
    Oct 2009
    I'm running 0ga wiring from the battery to the amplifiers, and 0ga earth cables to chassis. When I do play my music at a reasonable level, my headlights dim when the bass hits. Battery has also been upgraded to an Optima D34, so I'm assuming the alternator to battery wire is a bottleneck.
    So I'll have to find out what needs to be removed to gain access to the alternator. Has anyone done this before?
    Adelaide hills, SA
    You need to upgrade wires to the lights. Is the optima battery higher capacity than the original one?
    Oct 2009
    The optima battery is a deep cycle which seems to be the most recommended battery for car audio.
    The lights are standard halogens so I don't understand why I would require upgraded wiring for them. As the amplifiers can't seem to get enough power they draw it away from the lights?
    I've done some research in regards to large audio systems causing lights to dim and they suggest doing the "big 3" wiring upgrade. alternator - battery positive, chassis - negative and cylinder - chassis ground.
