On the off chance they put it in the same place as a T4, look just forward of the front wheel arch, down low. On my T4 it's on the passenger side.
Hi
I have a Stebel Truck hornto replace my stock horn.
Only I can't find the stock one anywhere, so i'm not too sure what to remove to get at it. I got my wife to honk it while i was under the bonnet and it seems to be on the right hand side opposite side from the battery.
Does anyone know where it's located.![]()
2009 Transporter T5 2.5 128kw LWB Manual (Black)
2009 Golf 90TSI Manual (White)
1998 T4 LWB 2.4D
2007 Ford Escape
Google Climategate
Get down low on the drivers side. it is located behind the fog light cutout. Access is from underneath after removing a few t screws on the bottom panel and into the wheel arch. Very easy to do. I was going to update with a stebel but instead have gone for a 65cm truck air horn mounted transversly under the bumper. Already have an air system on board so all it required was a bit of extra plumbing. The result is truly terrifying. My air tank is a 9 litre stainless mounted under the tray and because it is sort of visible, I painted it blue and slapped on a NOS sticker. Get some funny looks, good for a giggle but NO I DON"T randomly blow the horn.
