Results 1 to 4 of 4
Thread: Load Rated Alloy Wheels
    Hi Guys,
    What Choices do i have for load Rated alloys- not Factory- for Vw 2010 Transporter Dual cab ute
    Stud Pattern is common But 690 kg is not enough for a dual cab work ute
    Thanks Again
    Ajk
    Mt Cotton
    You would be advised to consult a wheel and tyre specialist as you need to keep the wheels within specs for insurance and obviously RTA . I have fitted a set of wheels from a VZ Holden Crewman as it also was 1 ton rated . Howard
    May 2009
    Been done many times before, this is what I have done to my dual cab.
    http://www.vwwatercooled.org.au/foru...tml#post334225
    Thanks for your reply
    Min wheel size for 132kw inclusive of factory bigger brakes on this model is 17''
    ill keep looking, but its not easy solution for anything that has a larger load rating than 690kg
    bmw-Holden- landrover 5x120 etc
    thanks again
