Results 11 to 20 of 21
Thread: Lift up roofs
    Now Adelaide!!!
    Jets...
    Thanks for the information and the web links.
    Its good to know there are some companies that could help me.
    Will have a proper look at the web sites and send them an email.
    Cheers again Rob
    May 2017
    The Shire NSW
    Hi Rob
    Just wondered if you found out anymore about this?
    I know Reimo are now over here so wondered if you had any more info? I want to pop a t5 swb and notice on another post you had mentioned no-one here would.
    cheers
    Jul 2016
    Thats an old post, so ill pipe in as I'm converting a camper at the moment.
    Southern Spirt Campers import the Reimo up here in Brisbane.
    Reimo Australia should be up and running and the email for Reimo Aus is
    frank@reimo.com.au
    As for service, i couldn't tell you about Frank, i emailed about some Reimo products and i never heard from him, so i just imported straight from Europe.
    Cheers,
    Bryn
    2017 VW T6 3200KG GVM LWB 132kW 7 Speed DSG (Campervan Conversion)
    May 2017
    The Shire NSW
    Thanks for the reply Bryn, I ended up getting a Multivan so wont be popping but I am road testing the bus this weekend camping ))
    Feb 2018
    Perth, Western Australia
    Sorry that this is an old post, but does anyone know what happens to all of the electronics in the standard roof when replaced by a pop top? "
    I'm referring to the aid conditioning controls and lights etc?
    Mt Cotton
    Fairly obvious that any wiring for the tail lights etc would probably just be moved sideways to the very outer edge at the sides , the factory wiring is along the left side and after conversion they would just refit it . As for interior lights side mounted would be done or some roof mounted with custom wiring to supply power with roof extended might be an option . Air vents I am afraid would most likely be lost as there is ducting through the roof cavity that would not be compatible with a conversion .
    Feb 2018
    Thanks for the quick response, always thought there would be a compromise
    Sent from my SM-G935F using Tapatalk
    Feb 2018
    Has anyone done it to a Multivan that could share photos?
    Can only find the VW California's online which are made from factory.
    Sep 2007
    Macarthur, NSW
    Quote Originally Posted by tiagodanda View Post
    Here are a few photos
    Ducting and lighting re-routed but airflow is not as strong to the very rear... that said the Multivan ex-factory does not have a roof outlet in the very rear.
    Feb 2018
    Quote Originally Posted by syncro91 View Post
    Wow thats great.. Thanks for the photos..!
    Is the bedding comfortable on the pop up roof top?
