Check out genuine volkswagen I've fitted them I know they do a billstein kit. Or even call heasmans located in Tempe nsw
Can someone suggest a source for a 50mm, or so, lift kit for a T5 4 Motion? Just bought an ex-ambo 4 Motion and want to lift the body a little for increased ground clearance. Camper conversion is underway. Tried a forum search but no luck.
Iza
I need to find out where the nearest service centre is so I'll ask then. Thanks.
Iza
I had 50mm lifted springs in the front of mine. They were very harsh and after finally getting so fed up I had some custom springs made. I now have 50mm lift but a much better ride. It still handles very well and I am so happy with the result. If you contact Pedders at Keswick they could give you them.
Just contact them by the look of it. http://www.pedders.com.au/sites/defa...1241679148.pdf
I think they were around $300. They didn't weigh etc. I had 18.5mm or so wire and we took an educated guess to go with 17mm wire with the same turns. The 18mm were just ridiculous, leaving me cringe at the sight of a pot hole. Now its great and no real loss in handling.
The rears are still the heavy option as I have a dual cab and they don't bother at all.
Thanks for the info.
I thought I better clarify the amount of lift before I give a bum steer.
From center of hob to wheel arch ( horizontal plane not touching arch) is 470mm. How does that compare to standard?
Also the contact name for pedders that handled it all, was Kevin. Branch Manager 08 82979022
Are these 50mm lift kits street legal in OZ and what do the insurance Cos have to say?
