Hey Guys,
Been a while still doing work to the van , Ive discovered I'm the most anal person on the planet which stops things progressing quickly, I really have to stop it its taking far to long to set it up,
Anyhow I've had time in the middle of things to look up and measure the T5 suspensions,
Mine is factory suspension "upgrade 2 (heavy duty shocks and springs) for rough road use))"
The VW code name for this is 1BB, the standard suspension is 1BA (both have other variants dependant on vehicle type and other options on the vehicle) Maxi is called 1BH and is completely different strut to knuckle mounting and different wheel bearings and cannot be mounted to a normal T5 ,
NOTE: - None of these VW suspensions Provide Lift, NONE!
Factory specifications
Front:
1BA = 471 +/- 10mm (standard)
1BA = 455 +/- 10mm (certain Vehicles)
1BB = 471 +/- 10 mm (heavy duty)
1BH = 471 +/- 15mm (Maxi 3.2T)
Rear:
1BA = 479 +/- 15mm (standard)
1BA = 459 +/- 10mm (certain vehicles)
1BB = 479 +/- 15mm (heavy duty)
1BH = 479 +/- 15mm (Maxi 3.2 T)
My 1BB sitting at real world unladden values of: (all measurements from centre of wheel/hub vertical to under arch as per factory spec)
Front LHS = 442 ( lowest probably due to battery, , 2nd battery, Fuel tank, washer bottle and DSG etc all on this side near front)
Front RHS = 452
Rear LHS = 460
Rear RHS = 453
Now the section where i need input from the guys using Seikel
My hanging dimensions (IE: my 1BB vehicle on jacks, suspension fully extended and wheels are hanging, not on the ground)
Front:
LHS = 540mm
RHS = 540mm
Rear:
LHS = 530mm
RHS = 530mm
What is the dimensions of the Seikel kits when full extended / wheels hanging?
If any of you guys would be kind enough to jack it up and measure it It would be much appreciated , I am just trying to define if Seikel lift kits also give extra travel or just lift
I suspect just lift due to the CV's but curious to know , trying to see if the Buying the whole strut kit is actually necessary or just changing springs on my already heavy duty shocks/struts is sufficient,
Have heaps of other things to discuss on here with you Guys , just need to find time ![Face Palm](https://www.vwwatercooled.com.au/forums/images/smilies/facepalm.gif)
Thanks for your time Guys
Keep up the good work on this thread,
PS: Nice Vid Murph!, Need to get mine out there, looks like a great adventure !
PPS: Bruce how are the Yokohamas going?
Regards
MAD
2010, POLO, COMFORTLINE, TDI, DSG, REFLEX SILVER
2012 MY13 T5 Transporter LWB, 4motion, DSG, Retrofit Rear diff lock
