Results 1 to 7 of 7
Thread: Large Red Cable - T6
    May 2017
    Vic & Tas
    Hi, while packing my van ready to go away I noticed - under the passenger seat - a large red cable that seems to go nowhere. Does anyone know it's purpose? I could certainly make use of it if it's a spare (from the battery) for some unfitted accessory.
    2017 T6 2lt Diesel Manual
    The only person to get everything done by Friday.......was Robinson Crusoe.
    Adelaide hills, SA
    There should be, but maybe it’s missing in yours a red pull handle at the end of that cable.
    It’s a passenger eject feature.
    Just kidding, can you post the picture of the cable, how thick it is?
    May 2017
    Vic & Tas
    OK here goes...1st one is where the cable appears from below the floor covering
    Large Red Cable - T6-img_0866-jpg
    The next one is where it ends up - cable tied to a bracket
    Large Red Cable - T6-img_0869-jpg
    I suppose the cable (including insulation is about 5-6mm diam).
    Pacific Paradise QLD
    Didnt some have provision for a second batttery under that seat Have seen threads about not getting one too high or you may get a prickly feeling in your nether regions
    Aug 2016
    NSW
    Yeah, there was an option for a second battery under one of the seats.
    2018 Crafter Runner
    T5.1 6sp manual.
    Aug 2016
    South Yarra
    It will most likely go to an 80A fuse which would then go to an auxiliary battery located under your middle bench seat.
    This is how mine is wired from factory with the auxiliary battery option.
    I’ve since upgraded the 75aH NON deep cycle battery to 2x 75aH deep cycle batteries using a CTek D250s DC/DC charger to control charging/solar and run a 1500w inverter, an Engel fridge,volt gauge and a few USB ports.
    Solar panel is next along with more 12v and USB outlets at the rear of the van and some more lighting.
    First I have to add another window in the rear for increased viewing options for miss 2.5 on the longer journeys!
    Jul 2016
    Hi Markee pointed out, if it goes to a 80amp fuse its the aux battery option, mine is wired up the same.
    Although I've removed the 80 amp Maxi fuse, and took the battery out as I'm now running a Votronic Triple charger, DC-DC, 230 volt and Solar to a 240 ah lithium battery
    2017 VW T6 3200KG GVM LWB 132kW 7 Speed DSG (Campervan Conversion)
