Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Kombi second battery replacement
    Adelaide, South Australia
    anyone know what other battery will fit under passenger seat to replace VW supplied battery for Kombi Beach T5 '06?
    the original is a 80Ah Varda, the one they say now fits is a 95Ah Varda @ $345, but are there any other brands that will fit in that space and that may be cheaper and stronger 100Ah+.
    Nov 2007
    QLD
    Hi Tapsy, good to see you still have your beach, so have we, and just returning home from a trip to NT.
    Our original battery died last year and as we were in Broome we got the only one in town that would fit which was about the same as the original. Since then, as the original is not a deep cycle, we would also like to fit a larger and deep cycle type to our van.
    I did investigate a Ritar 120Ah which would need to be laid on its side to fit in, but I am a bit hesiatant about that. Also most deep cycle do not have the lower flange for clamping so a new method of clamping would need to be found.
    So the simple answer is that I am also trying to find a larger capacity battery that fits, but also want deep cycle and easy fitment.
    Brian
    Now Adelaide!!!
    Hello Tapsy,
    Not seen you on here for a while, hope things are OK?
    Transporter can get batteries for your Beach he priced one for my Multi as I have the cable on its way from VW to retro fit second battery.
    If he does not see this thread give him a shout.
    Rob
    Adelaide hills, SA
    Quote Originally Posted by tapsy View Post
    Yes, you can have 100Ah deep cycle SLA batetry that is more suitable than starting battery for similar money or maybe a bit less.
    Now Adelaide!!!
    I told you he was the man to speak to!!!
    Thanks Miro
    Adelaide hills, SA
    Quote Originally Posted by BrianJ View Post
    Brian
    I'm sure that the Optima would have a deep cycle battery with the lower flange. But it's not that difficult to bolt any battery using the bracket from the top and use the hole(s) that are there for securing the flange.
    second battery
    after a looking around come up with what WILL fit under the seat and approx prices:
    1) original Varta battery 80Ah $300 (wet cell) Not Deep Cycle (000 915 105 DH)
    2) Bosch 80Ah $140 (same size) (wet cell) Not Deep Cycle (58014)
    3) Varta 80Ah (wet cell) Deep Cycle $330 (956 002) (on web site states as 60Ah but have been told it is a 80Ah)
    any size with larger Ah will not fit in space, mainly too long
    My question is: for @ $330 would a deep cycle be better value than the $140 Bosch
    I have been told that a non deep cycle does not like being run flat and after a few times will fail whereas a deep cycle can run flat and be recharged without that problem ?????
    Adelaide hills, SA
    Also the battery voltage will drop faster in the starting battery than in SLA deep cycle (it means shorter running time), and some of your accessories (some fridges and 240V inverters) that you run from that battery may have the circuitry that will switch itself off to protect your battery going completely flat.
    Nov 2007
    QLD
    I would prefer a 120Ah deep cycle if possible, so far I can only find the Ritar and it will only fit on its side.
    Brian
    Brian
    G'Day Brian
    What sort of money you looking at for that one?
