Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Kombi second battery replacement
  1. #21
    Jul 2007
    I noticed the warranty. Any idea why so short? I've had a good run with Century batteries in the past.
    EDIT: Gees I'm dopey. I just noticed the caps on top - it's a flooded battery. I was so focused on the dimensions I missed that detail.
  2. #22
    Adelaide hills, SA
    Quote Originally Posted by MultiplexMan View Post
    This one is 210mm tall and Deep cycle AGM Century Batteries Australia ($290).
    This one 200mm tall http://www.centurybatteries.com.au/s...tteries/ID-225 ($330)
  3. #23
    Jul 2007
    This one 200mm tall Century Batteries Australia ($330)
    The 200 tall (123 Ah) looks the go. I have to check that the cables will reach as the terminals are opposite hand.
    EDIT the stock battery is 187 mm tall. Add the rubber cover and it is flush with the seat base at 190 mm. B_gger!!!
  4. #24
    Adelaide hills, SA
    Is there a tray under the battery? I have a bench set and there was one, so I removed it, shortened the legs a bit to gain more space above.
  5. #25
    Jul 2007
    I'll pull the battery out tomorrow morning. I've got it on charge at the moment.
  6. #26
    Feb 2017
    You can fix wet cell batteries, so no need buy new
  7. #27
    Jul 2016
    Quote Originally Posted by Beach 70c View Post
    With the price of AGM deep cycling batteries these days, there's no point in trying to fix a stuffed wet cell, unless you want it for around home.
