A few weeks ago we decided to take a few days holiday in Yorke Peninsula.
This pic. is taken in Moonta Bay. Just to the left is a lit prominade leading to a very good fishing jetty.
A couple of nights later we stayed at Edithburgh, another top spot.
I spoke to the driver of the T3 on the left. He was enjoying the camper but it wasn't his. It belonged to a friend of his, must be a good friend.
After driving for a while I was looking for the cruise control switch that my other van has. The handling is better on the syncro compared with the 2WD LWB with good turn in. The economy was much improved at the correct tyre pressures & staying under 100km/hr. The lower gear ratios are great when driving as a tourist not so good for travelling long distances at higher speeds.
A few notes about the Trakka conversion. The side cupboard is mounted a little too far forward. As a result the drivers seat was too upright in the rearmost position. A 50mm extra would have improved comfort.[ I'm 6ft tall] The swivel seat still had sufficient headroom.
If I was ordering new I wouldn't bother with a drivers swivelling seat. It's a bit of a hassle to swing around & because of the cupboard behind it stops at an angle. Ok if you want to have another couple for a drink but with just 2 of us we didn't use it.
The 65litre fresh water tank has a handle at the rear & a pair of wheels at the front. At the end of your trip it's easily removed & with 2 large caps on the top can be dried out to stop algae forming.
My van is fitted with the 68litr fridge[mid '01] While with carefull loading it carried our stuff, the later 85 litre would have been obviously much better.
While away we found an "easter egg" in a concealed postion against the headlining inside the sliding door. It's a towel rail that proved very usefull.
Mods planned to do at some stage is to install a digital volt meter for the leisure battery, inside/outside temp gauge & cruise control. A reversing camera would also be usefull when lining up the trailer & general parking.
Numerous Mk1 Golf diesels
