Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Jets has bought a new T4 Camper!
  1. #21
    Camden, Sydney
    The vent in the bumper means its from a caravelle and is for the rear AC.
  2. #22
    Jun 2006
    with the dust and flies in western Victoria
    Quote Originally Posted by jets View Post
    I am slightly disappointed with the fuel consumption, slightly higher than the 2WD auto, although the tyre pressures were down. 2 tankfulls on the way home, driving gently, gave almost the same figure of just under 9l/100km [32 mpg]
    In a VW brochure Caravelle & Kombi Mar. 03, they claim a highway cycle of 5.8l/100km. In another Caravelle brochure "according to AS 2877" highway 6.8l/100km. I know the Syncro would use more, [probably .5l/100km extra] & my camper weighs more, I can't see myself getting anywhere near those figures.
    The syncro, even though it has the higher geared option [PR OZN] it's still lower geared than my 4 speed auto [ also high geared] At 110km/hr. the auto revs at 2600 while the Syncro is doing around 2750 rpm. The lower gearing is beaut around the burbs though, 4th gear at the now usual 50km & 5th can be engaged just over 60km. Before I bought the van I checked with a friend who had a syncro & he said a lot of the time he started in 2nd.
    While comparing the 2 vans, both '01 models, the syncro has an opening in the front bumper & under tray slightly left of centre. Is this for extra cooling of the gearbox?
    Jets.....VW quoted fuel economy in the T4 was assumed for a highway speed of 90km/hr.........hence the low number compared to rear world. My DOKA typically does 12L/100km on the open road mainly because it is running at such high revs at 110km/h but around town I regularily do better than 8L/100km.....for a vehicle this size there's little to complain about in that respect.
    Mine also has that 'hole'.....and it ain't a Caravelle. Nor does it have rear air-con. Unless you happen to be sitting in the tray. No idea what it's for.
  3. #23
    May 2006
    Adelaide South Australia
    I agree Seano, the the 5.8 figure would be at a constant 90km/hr but I would have thought the 6.8 would have been more realistic as it is to AS 2877. Anyway I will check again on my next trip with correct tyre pressure. The PO said he normally got 9.0 in normal running around including suburban use. From my experience diesels give the best economy at lower revs, so I agree with Seano in an earlier statement that he made that his Syncro could do with a higher top gear.
    BTW could anyone else with a Syncro confirm whether their's has the opening in the front bumper.
  4. #24
    May 2006
    A few weeks ago we decided to take a few days holiday in Yorke Peninsula.
    This pic. is taken in Moonta Bay. Just to the left is a lit prominade leading to a very good fishing jetty.
    A couple of nights later we stayed at Edithburgh, another top spot.
    I spoke to the driver of the T3 on the left. He was enjoying the camper but it wasn't his. It belonged to a friend of his, must be a good friend.
    After driving for a while I was looking for the cruise control switch that my other van has. The handling is better on the syncro compared with the 2WD LWB with good turn in. The economy was much improved at the correct tyre pressures & staying under 100km/hr. The lower gear ratios are great when driving as a tourist not so good for travelling long distances at higher speeds.
    A few notes about the Trakka conversion. The side cupboard is mounted a little too far forward. As a result the drivers seat was too upright in the rearmost position. A 50mm extra would have improved comfort.[ I'm 6ft tall] The swivel seat still had sufficient headroom.
    If I was ordering new I wouldn't bother with a drivers swivelling seat. It's a bit of a hassle to swing around & because of the cupboard behind it stops at an angle. Ok if you want to have another couple for a drink but with just 2 of us we didn't use it.
    The 65litre fresh water tank has a handle at the rear & a pair of wheels at the front. At the end of your trip it's easily removed & with 2 large caps on the top can be dried out to stop algae forming.
    My van is fitted with the 68litr fridge[mid '01] While with carefull loading it carried our stuff, the later 85 litre would have been obviously much better.
    While away we found an "easter egg" in a concealed postion against the headlining inside the sliding door. It's a towel rail that proved very usefull.
    Mods planned to do at some stage is to install a digital volt meter for the leisure battery, inside/outside temp gauge & cruise control. A reversing camera would also be usefull when lining up the trailer & general parking.
    Numerous Mk1 Golf diesels
  5. #25
    Adelaide, South Australia
    Hi Jets, you have got a nice one there! looks in very very good nic for a 01,
    and is well set up!, hope you enjoyed yorkes we have stopped there before great place (moonta)
  6. #26
    May 2006
    Thanks tapsy, yes it is almost as good as it looks in the photos, I'm very pleased with it.
  7. #27
    great work, im working on converting my swb '94 into a camper, seriously thinking about getting some proper caravelle windows instead of the panel van side. how much heat do you loose through your windows ? i can insulate the panel van side which is the bonus of keeping them that way.
    cheers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
  8. #28
    Now Adelaide!!!
    DVR68U,
    There are lots of caravelle converted campers over here in the UK.
    We use these thermo mats to stop heat loss.
    We also have some that go round the outside of the cab.Here is a picture of both types
    [IMG][/IMG]
    As you can imagine we suffer from heat loss more than you lot out there!
    There is also a thermo screen for the pop tops.
    Rob
  9. #29
    May 2006
    Quote Originally Posted by DVR68U View Post
    cheers brenton
    The side window behind the driver is a double glazed awning type while the rest are Caravelle style. While we were away there wasn't any problem with inside temp although there was a fair amount of condensation in the mornings.
    Normally we take a fan heater away with us but this time decided against it.
    Unless you were camping in the mountains in the middle of winter I think what you are planning should be fine, they are very cosy inside.
    Rob, when I bought my first van I purchased some English magazines & saw the insulated covers & was wondering if they were needed here.
    We normally avoid the hot weather when holidaying & much prefer Autumn & Spring. After a few trips including Tasmania in May we found they weren't necessary. BTW where was the photo taken?
