Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 73
Thread: its dead, and vw killed it
    Oct 2010
    Melbourne Victoria
    as a rule of thumb - on any car really - is when the timing belt is changed, change the water pump - most of the money spent when doing these jobs is labour.
    Aug 2008
    Is there any way of finding out if the pump has been replaced? I got mine used with 85k on it, now has 145k on it.
    When should the belts be replaced?
    2014 T5.1 Multivan Tuned by Pendle Performance Australia
    Adelaide hills, SA
    Flexible couplings at 120,000km.
    Look at the water pump cover for the spanner markings on the 3 bolts.
    sydney nsw
    ive got the 2.5 tdi t5. vw told me there is no timing belt, but chain instead. so should i still be changing the water pump when it hits 200k. now 170k, was done at 80k
    Adelaide hills, SA
    T5's with AXD and AXE have timing gears, they're maintenance free. The water pump is easy to replace, the repair cost is high when the pump leaks coolant onto the oil and engine oil and oil filter have to be changed. Replacing w. pump as preventative measure should be cheaper. But, I wouldn't do it.
    Oct 2010
    Qld
    So is the current MY10 / MY11 have chains or Rubber timing belts?
    May 2010
    Lalor Park, Sydney
    I can't find anything on the net about which type. Should say it in the manual I'd hope.
    sydney nsw
    blank off egr
    im after someone in sydney that can blank off the egr in my 2.5 tdi t5.
    Jan 2008
    Sunshine Coast
    Have a chat to Parso Rex. You do realise that will raise your combustion temps, and possibly endanger your turbo?
    sydney nsw
    who is parso rex? how can i find him. i tried google and no luck
