Originally Posted by
Sunny43.5
I will jump in here with 50 years of experience behind me with car interiors , as you would have seen in both my links I have used the same product for that same 50 years almost . Now it is Underlay 900 GSM it Won't absorb moisture Won't rot or smell 'damp' Easy to cut and work with Good acoustic and comfort performance . I think from memory its at least half the price of what Stage 2 is for a start for the same amount of meterage . Its not so much how good the product is its the attention to detail in application , the better its fitted corectly the better it works .
In all the vans I have done they are as quiet as most cars inside with very little road noise or other noise intrusions after installation . If you look at both jobs there are different photos taken at different times in one you can see lots of alloy tape covering up all the holes along the sides also same photos at the bottom of the body cavities there are rolled up 25 mm foam pieces which are blocking noise coming up from the road along the rockers and wheel arches . Inside the pillars where no acess was possible expander foam was used . You can buy the 900 GSM Underlay from your Nolans UDA outlet in Melbourne .
Sunny43.5, is this similar to the Underlay 900GSM you mention from Nolans; Underlay 900 GSM | The Nolan Group
Below is a picture of a 2015 Ford Mondeo Titanium Wagon that I once owned (the underlay was OEM on the Wagon, not the hatch however).
I am trying to find the "underlay" that Ford uses to do a similar thing to my ŠKODA Superb.
Any thoughts / suggestions?
