Page 3 of 10 FirstFirst 12345 ... LastLast
Results 21 to 30 of 91
Thread: Installing a light bar or driving lights
  1. #21
    Mt Cotton
    If you look at Markees and ours its not worth worrying about , it just does not make any difference and we often tow a fully loaded trailer and van full of MX bikes and gear .
  2. #22
    Jan 2017
    AUSTRALIA
    Thanks guys. Saw what u guys have done & thought it was a great idea. Someone mentioned to me it might be worth looking into any issues with blocking airflow, but clearly u guys haven't had an issue, which is what I was hoping to hear.
  3. #23
    Feb 2015
    How do you guys mount the LED bars in the grill area without removing the whole front bumber bar?
  4. #24
    Mt Cotton
    You will need to remove the bar as its the only way to get a nice flush fit , its not as hard as you would think to remove just a few plastic clips and scews etc .The main thing is to make sure you cut the hole neatly so it fits in nicely . Is yours a first generation T5 the later T5.1 ?
  5. #25
    Feb 2015
    Mine is the later 5.1 (2012)
  6. #26
    Feb 2009
    NSW
    I just did this, then mounted it all back together only to have the led aiming too low! Ugh... Now I have to remove the bashguard to get to the bottom 3 bolts of the bumper... Might try find my hole saw...
    Sent from my SM-T813 using Tapatalk
  7. #27
    Mt Cotton
    I must have been lucky as both Light bars I fitted to our 2012 and my early 2005 ended up perfect in the aiming department .
  8. #28
    Jan 2017
    AUSTRALIA
    Ozgti, have u got any pics? I'm looking at getting on of these tomorrow.
    Adventure Kings 20" 'Lethal' Slim LED Light Bar , 4WD & Outdoor Products - Australia
    Will pull the front bumper off first I think. Any tips?
  9. #29
    Feb 2009
    NSW
    Quote Originally Posted by Yogi72 View Post
    Yeah, get a side mount not bottom like mine. So much effort to adjust it.
    Get a lot of extensions and good sockets.
    Be prepared to get sore jamming your hand inbetween intercoolers and bumpers.
    Get some rags and cover the threads that the 2 10mm nuts go onto. Ask me how I now know to do this!!
    I probably could have gone higher, but I used the led bar o had when it had a nudge bar. I have a longer 32 I think at my storage which I'll eventually put on. Might weld the bracket on...
    Sent from my SM-G930F using Tapatalk
  10. #30
    Jan 2017
    AUSTRALIA
