Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 61
Thread: installing aftermarket stereo in T5
    Adelaide hills, SA
    Quote Originally Posted by gregozedobe View Post
    The power drain I'm referring to is more insidious than that - everything looks like it is switched off, but one unit is polling the other all the time, so it never switches off properly (ie goes to sleep), thus draining more power than it should. I gather it is something to do with the canbus connections. Quite a few threads on this forum refer to the problem, mostly related to changed AVEs.
    Usually only noticed if the vehicle isn't driven for a few days or more, if you drive every day or every second day the battery gets charged up again before it gets flat enough for you to notice.
    Yeah, the problem gets usually noticed in winter time.
    Oct 2009
    I'm also wanting to install a cheap eonon double din head unit into my T5 just for a reversing camera installation.
    Does anyone know where i can find a tutorial on installing a oem head unit in a T5?
    I've got a 09 T5, so what exactly is this "CAN BUS" thing? What does it do? Can i do without one?
    Thanks
    Adelaide hills, SA
    Quote Originally Posted by lemmiwinks View Post
    Thanks
    What radio you have in your van now?
    CAN-Bus
    Oct 2009
    CAN-Bus
    I've got the standard one that comes with the van. Like this one:
    Just briefly read that can bus page. To my understanding, I can just install the eonon head unit into the van and connect the can bus to the "impart ican system"? Is this so called "ican" system already in the van? Or do i need to purchase it?
    Thank you for your help!
    Jan 2007
    sydney
    You do not have to hook up the can wires. You need the powered antenna adaptor and acc pick up from streering colunm. Thin Brown/Green via a relay, works a treat on my T5 with a Alpine IDA300e
    1st place Mk3 Standard 08
    Oct 2009
    Is this the adaptor that is required?
    http://cgi.ebay.com.au/VW-AUDI-BMW-C...item2303c5a24b
    Aug 2013
    T5 Stereo installation
    Hi
    I'm picking up a 2012 T5 on Monday (although it was made 2010 and complianced 2012) and I want to fit a 2-din stereo and reversing camera.
    Is Can-Bus an issue for the sterio requiring an adapter? Or is the only thing I need the aerial adapter? And last question is where is the best source for the parts?
    An image of the stereo is below so everyone knows the model
    Thanks in advance
    McGraths Hill
    Do a search, or look a couple of threads down the page, T5.2 oem radio options. Been covered alot before.
    Aug 2013
    Mate I saw the OEM thread but I'm not looking for an OEM radio and couldnt see anything on the aftermarket side
    Nov 2007
    The OEM's are far better than any of the alternatives IMO. I have/had OEM RNS510s, cheap chinese ones and better chinese ones so I talk from experience They worth every extra $$$ .....
    If you are set on a non OEM, I'd recommend these, they have an OEM style interface and local Aussie support with free firmware and map upgrades for life. Group Buy / EOI new generation DNS head units (RNS-510 alternative)
