Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 61
Thread: installing aftermarket stereo in T5
  1. #51
    Adelaide hills, SA
    Quote Originally Posted by kordo View Post
    Sorry was half asleep when I replied. What is the username of Audi upgrades so I can PM them about the RVC adapter?
    So are there any mods needed to fit an RNS510 or RCD510? or do they just plug straight in?
    liquidforce View Profile: liquidforce - VWWatercooled Australia
    the RCD510 and RNS510 are P&P
  2. #52
    Aug 2013
    cheers
  3. #53
    Aug 2013
    So does the RNS510 and/or the RCD510 fill the gap in my dash exactly? Or will I need adapter plates if I take this option?
    Hi
    I'm picking up a 2012 T5 on Monday (although it was made 2010 and complianced 2012) and I want to fit a 2-din stereo and reversing camera.
    Is Can-Bus an issue for the sterio requiring an adapter? Or is the only thing I need the aerial adapter? And last question is where is the best source for the parts?
    An image of the stereo is below so everyone knows the model
    Thanks in advance
  4. #54
    Adelaide hills, SA
    You shouldn't need an adapter for this one. The RNS510 bolts straight in. Give liquidforce a call, he will sort you out, especially if you need the RVC as well.
  5. #55
    Aug 2013
    Sweet so just plug in the RNS510, VW bluetooth module and the RVC from liquidforce? No issues with the MFD or anything else?
  6. #56
    Aug 2013
    So I was doing some reading on this in the other threads and it appears fitting the bluetooth can be a PITA. What's the issues with this?
    Also what nobody has anwered here is why does the head unit have to integrate to CANBUS? Cant a unit be connected to earth, +ve, acc(+ve) and speakers to run independently of the car?
  7. #57
    Mt Cotton
    You could wire it independently as you describe but some features may not work , for instance the factory wiring has the reverse camera trigger wire so you would need to use some of the factory wires along with the new ones . Look I can only repeat what I said and it is a personal opinion if you buy one of the Chinese ones it comes with every thing you will need adaptor for Can bus the lot and Bluetooth is a breeze you just put your phone no matter what brand into discovery and it will find the head unit then it will ask you for the head unit code usually 0000 or 1234 and that's it you will have all your contacts and you can use the head unit to control your music streaming via Bluetooth answer calls everything a reverse camera will set you back an extra $25 Most units will come with Digital TV built in GPS Ipod connection USB ports and heaps of extra connections for rear headrest DVD players and Amplifiers . Probably the hardest part of installing is tucking all the wires back behind the unit as you slide it back into place , but it does look the same as any VW units except its just CHINESE ! Personal Opinion please remember .
  8. #58
    Aug 2013
    Yes but then how does the sound quality compare? And I've heard the chinese units are not good for radio
    Plus which chinese unit
  9. #59
    Mt Cotton
    Okay my last contribution on this one , okay the Chinese units are cheap and yes the radio is not very good but is it the unit or is it the VW antennae system ??? it has been a very known problem for some years that some aftermarket and well known brands have problems being compatible with the VW antennae system not just in the Vans lots of other models report the same problem . Quality of sound again horses for courses if you are an audiophile don,t buy Chinese , I am a bit of a music nutter and have been for over 40plus years up until a few years back I had nothing less than top of range Pioneer systems in my cars . But as time has moved on and we all look for that little extra like GPS Bluetooth and all the other things these were not available through Pioneer etc , even today Pioneer do not have the same features that I like in our Chinese one . Now for sound quality what speakers do you run stock or aftermarket ?? all of our vans have had speaker upgrades if you saw how cheap the factory ones are it is shameful . I always retro fit Pioneer or Kenwood or Alpine speakers with splits for the high and mid range frequencies and then subwoofers . My work van has two 12 inch Pioneer subs tucked away behind my compressor in the rear , then I am running two amplifiers one for subs only and one four channel for tweeters and midrange . I will agree the volume that I was able to achieve with the older pioneer unit cannot be matched by the Chinese it is probably their Achilles heel as their preamp output is not stable so I have fitted a Line Driver which increase the out put from the head unit from 2 volts up to 9 volts stable which gives a 28 db gain . Am I happy with that set up ? hell yes I still get complaints from my neighbour's all on acreage when I drive by , if you are connecting the head unit on its own without amplifiers I cannot comment on quality as the "claimed " 50 watt x 4 by the Chinese could not be guaranteed . Once you get past halfway in volume you will start to get distortion , that's why I run mine through amps gives a much better sound quality at a lower volume . The Chinese have several manufacturers and many of them are sold through a variety of sellers , in some cases I have seen Australian suppliers selling the identical unit I could buy from China direct at ridiculous marked up prices so its your choice , I have posted my favourite further back on this post but in case you missed it vw au items - Get great deals on Special Car DVD Player items on eBay Stores!
  10. #60
    Rozelle, NSW
    I am doing a factory Handsfree set kit instal and stuck on getting leads out of a plug as they need to be moved to a different plug. Any suggestion for this
