Results 1 to 9 of 9
Thread: Increasing Fuse Amps In Cigarette Lighter - Safe?
    Sep 2008
    Gold Coast
    I've just bought one of those plug-into-the-lighter-socket FM transmitter devices that sends an audio signal to the radio so you can play MP3s and it appears the first thing it did was blow the fuse in my 1998 T4. At least I know that the fuse was ok before because I'd run an airbed pump off it.
    Anyway, I subsequently tested the device in my Ford Escape and it runs ok in there.
    The Escape has a lighter fuse rated at 20A and the T4 has a 10A fuse so here's the thing - would it be ok to put a 15A or 20A fuse in the T4 so I can run this device? Would the rest of the circuit be ok or is the wiring at risk of fire with that kind of draw on it?
    I must say I was surprised after running the device for only 3 or 4 minutes in the Escape to find the shaft that plugs into the lighter socket had become quite warm, bordering on hot.
    I'd welcome any thoughts on the matter from anyone with auto electrics experience. It'd be quite a pity to cause a fire in the dash!
    Boronia VIC
    There's no way that gadget should be pulling that sort of current.
    I suggest you return it before it does damage your car.
    At most I'd expect a FM transmitter to draw about 0.3 Amps, your's is drawing between 10 and 20 Amps! There's something very wrong with it.
    Pete
    Sep 2008
    Gold Coast
    Pete
    Thanks for the advice, Pete. After I'd posted my question I checked the booklet for the air pump I'd previously used (a Coleman AirPort) and found it pulls 4-6 amps. If a little electric motor only pulls that much you're certainly right that a solid state item shouldn't be pulling over 10A. It's going back.
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by Deeceer View Post
    I think thats the best idea, although testing with a multi meter would be worth a shot if you have one. Your fuse may well have been old and failling due to some other incident and just happened to go at that time, although with the heat your talking about, maybe not....
    Jul 2005
    agree. should be bugger all current draw for an electronic device
    1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
    Sep 2008
    Gold Coast
    Well, the seller (via Oztion) was happy to replace it so it's winging its way back to him via AusPost though if the next one blows a fuse or heats up like its mate I'll be chasing a refund.
    I managed to find full specs for a similar device online and that was claiming a power draw of 0.4A, plus or minus 0.1 so Pete, your original estimate was good.
    Thanks for the advice everyone!
    Sadly the return postage is starting to make it less of the bargain it appeared in the first place.
    Adelaide hills, SA
    Couldn't it be connector (plug) on that device?
    Sep 2008
    Gold Coast
    Quote Originally Posted by MRL T5 View Post
    Certainly it was the connector portion that got hot. It'll be 'interesting' to see how the replacement one performs.
    Sep 2008
    Gold Coast
    ... And the replacement appears to perform ok. The plug gets a little warm over time but it doesn't blow the fuse.
    Thanks to all for assistance with this
