anyone....is it the idler itself.....or something else.
cheers
AL
2001 TDI 2.5 ACV, as the tittle describes at Idle Air Conditioning stops, Idle up AC Back On, i mainly commute on the Freeway so its on the whole time only at a set of lights AC stops, i have done some research and i have been told by an Car Ac guy its the idler and the only thing is i have no idea where its located on the engine itself and how easy is it to change, some one else suggested i may have a hose leak (air) but i have replaced the hoses recently (is there a way to check air leakage) also when at idle and press the ac button (not fan but the actual ac on) the idle stays the same apparently its supposed to increase the idle rpm, is this still the idler.....
any help much appreciated or if i need to answer any other details please let me know.
2010 Jetta 2.0l TDI 103
2010 Passat CC 2.0l TDI 125
2011 Passat 2.0l TDI 125
cheers
AL
hi al i to have a 01 2.5 tdi man, ac works great but piss poor on idle.i think it has some link to the thermo fans.ie my old 97 2.5 petrol ute would bring extra fan on when ac was turned on...but with my current tdi ute, this does not happen. seems we have the same prob.any one else ?
