Results 1 to 3 of 3
Thread: Holden 19inch Thunder Ute Wheels
    Sep 2014
    Capalaba, QLD
    I'm sure this has been covered before but I'm looking at a set of ve commodore thunder ute 19inch grey wheels. I have been told they are 750Kg load rated??? will these wheels bolt straight on to a 2013 T5?? if not what is required??
    Thanks Simon
    Nov 2007
    Those are nice wheels Simon. Not particularly wide but for a T5 should be no problem.
    The centerbore size on the T5 (and Amaroks) are different to the Holden and you would need spigot rings to center the rims properly. Ebay has lots, just need to order the right 1.
    Holden VE on 69.6mm => VW T5 65.1mm
    Mt Cotton
    Got VY VZ I ton V8 Holden rims on my T5 no problem with load or strength yes fit spigots or you will have balance problems .
