Page 7 of 9 FirstFirst ... 56789 LastLast
Results 61 to 70 of 84
Thread: Hi Ho Hi Ho its to off the transmision shop I go.
  1. #61
    Mar 2008
    JATCO and ZF Certified Automatic Transmission Factory Remanufacturer
    Sunny, give these guys a call for some independent advice on whether they clean or replace the filter (I suspect the latter). They are in Melbourne and do a lot of the warranty work for various makes. The gauze filter could quite easily be cleaned (with care) with a bit of petrol and dried out. Assuming VW is somewhat ambiguous, I would insist they replace it as part of the auto service. Regards, Scott
  2. #62
    Mt Cotton
    Thanks Scott but I want to know VW ,s schedule and process , if it turns out that they should have removed the sump pan and cleaned or replaced the filter I will have some ammunition for some recourse for the repairs I am now paying for . The guy doing ours was very informative and encouraged me to check on what they found , if I remember rightly he said he will replace the filter if he deems it needed ., or clean it perfectly .
  3. #63
    May 2010
    Kilmore, Vic
    Had my first rebuild there and won't be going back again
    Box went again 94,000 ks after that first rebuild and I was recommended to another shop
    Once it was opened up, and what was found, I realised the first rebuild was not as it should be
    You learn as you go
    M
  4. #64
    Adelaide hills, SA
    Soooo simple, if the filter is made/kept in stock/sold as the spare part then it should be replaced together with the sump gasket, sump cleaned/washed/dried before refitting. Never clean the filter that's not made as reusable, in which case it will state that the filter is reusable. When you drive the long distances, it doesn't have to be better for the AT, because you most likely overheat the AT, shortening the fluid's life (and AT too). If the transmission plug is not sealed properly it can get contaminated with water and dirt, so the Oring/gasket there, should always be replaced after the fluid change. The environment where you open the AT should be dust free, so never go to dirty shop for the AT job of any kind.
  5. #65
    Mar 2008
    You are right Transporter.
    I am going to get my auto serviced at 75K (new fluid, new filter etc). Whilst it is coming up for the 60K service, I don't interpret that the dealer will automatically caputure this in this service for a 2008 Tiptronic. Different for a DSG where it is as part of ther 60K service.
    Regards, Scott
  6. #66
    Mt Cotton
    Okay here are some photos of our auto eviscerated Auto , the black slime is what is all over the internal surfaces you can see the finger wipe on the sump pan . The filter is totally blocked you can see the parts of the filter dark in colour which is where the fluid is supposed to pass through the clear sections are where the metal membrane that supports the filter so no material is on that part . So its very clear that because of being sealed and VW will not remove the sump to service it then putting in fresh fluid is a stupid and fatal mistake . If they had replaced the fluid and the filter 3 or 4 year sago I doubt whether I would be in this predicament today . If they believe that they do not need to be serviced then surely this is undeniable evidence that their logic is flawed .
    [IMG][/IMG][IMG][/IMG][IMG][/IMG]
    sorry the last two photos were not the best focus
  7. #67
    Mt Cotton
    Interesting email from VW Germany today , will keep everyone updated will keep mum until something happens from the Australian end .
  8. #68
    Adelaide hills, SA
    Interesting, ....like some good news?
  9. #69
    Mt Cotton
    Well I wont break out the champagne prematurely but who knows , mind you they have instructed VW Australia Customer care to attend to the matter again . I have had one letter and a call from someone higher up in VW AU . I lit a fire under this caller so I wait with baited breath . Will update when something happens , but with evidence I now have I am sure this will make some waves . If you compare the auto in the Brickyard photos there is a glaring difference between the two his was essentially clean and mine is black with sludge it does not take Einstein to work out that the fluid in a sealed environment does decay and cause problems . Spoke to the dealer and they admit that they only change the fluid via the sump plug at specified temperatures , but because VW sealed for life they would not replace the filter , I cannot believe that they would ignore a crucial part of the auto ie the filter as it is a link in the movement of the fluid through the various parts and if blocked as seen above then catastrophic failure is inevitable .Lets face it we change oil filters evry time why not the auto and yes I know its internal but what the hey its six lousy 10ml bolts and a gasket that's probably worth $20 plus the filter small change for the sake of saving a whole transmission in my opinion .
  10. #70
    Adelaide hills, SA
    ...and what a load on the environment, driving around in the van with AT malfunctioning for who knows how long. With the sealed for life and the extended oil changes they're saving us what? A few litres of oil over the life of the vehicle, just to waste us/them heaps more in the process of rebuilding/replacing whole transmissions.
    I know they want to keep the economy going, but I don't think that's the way.
    If the fluid and filter would be changed at every 40,000km, the AT fluid wouldn't be so expensive, would it? But, even at $50 per/L it would still be a bargain.
