Results 1 to 9 of 9
Thread: Hi everyone ive recently discovered i have oil on my timing belt. Does anyone know wh
    Sent from my E6653 using Tapatalk
    Does anyone know where it could be coming from if its common and hiw bad is the situation. T5
    Quote Originally Posted by gt_tiling View Post
    Oil and rubber don't mix. Certainly looks like a fair amount of contamination. I am not familiar with Transporters but I can't see it being different to other VWs. Cam cover gaskets will leak. So I'd start there.
    Quote Originally Posted by h100vw View Post
    Thanks, is there a way to clean the belt and area without removing the belt. I read that most degreasers is bad on rubber belts.. The has to be something i could use
    Pacific Paradise QLD
    You will probably have to remove the belt to replace the leaking seal anyway. Cleaning it wont stop the problem.
    Mamba Ebike to replace Tiguan
    I wouldn't put anything on the belt that may degrade it further. Confirm where the leak is coming from but replace the belt as a matter of course.
    Waterpump etc if you're feeling flush.
    Sydney/Canberra
    It'll either be the cam seal or the cam cover gasket.
    You'll need to pull the belt to do the seal, so you'd be silly not to throw a timing belt kit and water pump at it while it's all apart.
    Parts should be cheap and easy to get, since it's just an old Golf motor.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Quote Originally Posted by Umai Naa!! View Post
    Thanks guys for the help,
    Umai naa!! Can you point me to a site or where i can buy all the parts that i need to do the fix (belt and gaskets and waterpump) im not sure which are the correct parts.
    Volkswagen Teile Katalog (Pats Catalog)
    Look it up here yourself. Add your location to your personal details, the CIA aren't fussed with broken VWs. That way someone can point you to local suppliers if appropriate.
