Quote Originally Posted by Umai Naa!! View Post
It'll either be the cam seal or the cam cover gasket.
You'll need to pull the belt to do the seal, so you'd be silly not to throw a timing belt kit and water pump at it while it's all apart.
Parts should be cheap and easy to get, since it's just an old Golf motor.
Thanks guys for the help,
Umai naa!! Can you point me to a site or where i can buy all the parts that i need to do the fix (belt and gaskets and waterpump) im not sure which are the correct parts.
You will probably have to remove the belt to replace the leaking seal anyway. Cleaning it wont stop the problem.
Sent from my E6653 using Tapatalk
