Results 1 to 9 of 9
Thread: Hi all! 2L petrol eng. oil
    T4er Guest
    I know this may cause a little controversy, but I realy need to know. what kind of eng. oil should I use? It's a t4 99 petrol, engine has 290k klm. but strong as blows no smoke. I've herd talk of synthetic oil but is that realy necessary? Also dose anyone know where I can get my hands on a owners manual or simmilar? thanx all.
    Jul 2005
    A good quality semi-synthetic oil will do the job. Make sure it has the Volkswagen approval numbers.
    Maris
    T4er Guest
    Is valvoline 10 w 40 ok? castrol magnatech seems to be much the same.
    Jun 2006
    with the dust and flies in western Victoria
    Workshop manual?
    Try this one - http://www.pitstop.net.au/view/marqu...ery/plu/16347/
    I have the diesel version and it is very good - not as detailed as the Bentley (factory) manual but is largely based on it and is considerably cheaper
    As for oil?
    The lube guide on the valvoline site is recommending a 15W40 engine oil for the 2 litre petrol engine.
    By the by, the lube guide on all oil company websites is managed by www.infomedia.com.au and distributed through www.lubeandtune.com.au and they have a very very handy summary service guide available for all T4's (and many other cars) for $5.50 per view (don't forget to print!!). Might be worth checking out
    Jul 2005
    From the Castrol website:
    CASTROL MAGNATEC 10W-40 A3/B3 - VW 505 00
    Make VOLKSWAGEN (VAG)
    Model Transporter Type 4: 2.0/2.5
    Engine P
    Year 1991-96
    Application Recommendation Capacity (ltr)
    Engine (P) Castrol's best oil for your vehicle EDGE 5W-30 5 / 5.5
    T4er Guest
    Talking
    Thanx for that, not easy tryn to get this old girl back up to scratch
    May 2006
    Adelaide South Australia
    Quote Originally Posted by T4er View Post
    At that mileage I would watch oil levels closely using a 10w-40 oil, also any hydraulic tappet noise.
    Aug 2007
    Horningsea Park
    Valvoline Premium XLD 20W-50
    Luke
    Aircooled & Watercooled Nut
    62 and a Half Bug
    02 Bora V5
    T4er Guest
    Thumbs up
    Ok all done I used the val. 15/40 semi synth. & I must say it has never run better. with the k's this thing has it sure dose run smooth. Thanx so much for all the adv. Cheers
