Results 11 to 20 of 22
Thread: HELP! T4 owners. Relay in wrong spot?
    Now Adelaide!!!
    Quote Originally Posted by t4tradie View Post
    Plenty of info over on the t4 forum about this stuff. Hope it helps.
    Good info T4Tradie!!
    But if GlowPlug has not paid his subs he will not be able to see (8% of the T4Forum.
    You could try looking on The Brick-yard
    There are lots of helpful people with lots of knowledge on this website and its free....
    Rob
    Jul 2010
    I. My radio would not work on the acc position, however would power up just before reaching the acc position and then drop power.
    This is what mine does now.
    I have ordered a manual online, and will look up the ignition switch like you have mentioned. Where would be the best place to buy one?\
    Thank you for your help it's greatly appreciated!!
    Aug 2007
    it's a 10 min job to replace. You have to modify a small phillips head screwdriver to allow to to remove the mounting screws. the screwdriver needs a 90 deg bend put in it. You will see what i mean when you look at the bottom of the ignition barrel.
    You could try hsy ( South yarra auto parts in Church st Richmond) Imparts on Hoddle st Abbotsford may also be an option ( i think they may only wholesale to the trade) otherwise genuine. Hope this helps.
    Jul 2010
    Sorry to sound stupid but when you say ignition switch, do you mean ignition barrel?
    Hopefully the manual i have ordered will show me what your talking about.
    And is it a job a woman can do, or will i need to have stregth to replace it?
    Aug 2007
    The ignition swith screws to the bottom of the barrel via 2 small phillips head screws. Fairly straight forward, just a little fiddly, hence the screwdriver with a 90 deg bend. Remove the steering colomn shroud along with fuse panel cover to allow good access.Have a look at the base of your ignition barrel, the switch will possibly be black in color with an electrical plug on the bottom. Once you sight it, it will all become fairly self explanatory.
    Jul 2010
    Thank you, I will order the part today and when the part and manual arrives I will give it a try. Fingers crossed i can fix it.
    Thank you for ALL your help!
    Jul 2010
    I called hsy, they only supply trade as does the other place.
    Any other ideas?
    Adelaide hills, SA
    HSY in Adelaide will help you. Call Daryl 08 82776493
    May 2006
    Adelaide South Australia
    Or Imparts in Adelaide. 1300467278, ask for Dean.
    Numerous Mk1 Golf diesels
    Jul 2010
    Thank you very much the part has been ordered and should be here tomorrow.
    Now for the next saga of installing it.
    Thanks for all your help so far, it's a great little community you have here, very helpful.
