Quote Originally Posted by Sim T5 View Post
Thanks All, I'm happy to pull apart and replace the drive as im a technician.....my issue is that there is no point replacing drive if I cannot get the os and maps reinstalled...also the stereo is not installed as yet so easy to ship if needed for repair....Cheers Simon
OS and Maps are easy to do. Once you have the drive replaced (and I'll also recommend Kamold's SDD upgrade) I'm sure somebody local can help you out with loaners of the necessary software.
I can help code with VCDS to enable it to work with the MFD,
