g'day Bryn
I have a Trakka supplied Transporter MY14 3200 GVM TDI 400 DSG LWB 4Motion with factory fitted Seikel HD raised suspension - this is my 9th bus (16th vw) and is by far the BEST suspension setup of any VW I have driven, I use it as my daily ride.
Tyres are 215/60 R17 - sidewall height when inflated & vehicle is on the ground 100mm, off the ground 107mm
As for my jacking setup, the front jacking point is 260mm above ground, rear jacking point is 310mm above ground.
The jack supplied by Trakka (not VW) for 3200GVM is an Omega BST2000 bottle jack rated to 2,000 kg. Retracted stands at 250mm, fully extended is 470mm
doing the maths on that - the frikken jack is not tall enough to put on a fully inflated rear tyre - on level ground ! - as another poster noted, blocks of wood are your friend, for so many reasons in addition to changing tyres, I now carry 4x80mm treated pine sleeper off cuts, usually used in leveling the vehicle at dodgy camp sites.
For what it is worth, it is possible at the time of ordering the vehicle, to have additional Seikel items put inside the car for shipping to Oz, I ordered the Seikel sump & gearbox bash plates that shipped inside the car & were fitted in Oz.
ML
