Results 1 to 10 of 15
Thread: A hot seat in hell!
    Jun 2011
    Vic
    A hot seat in hell!
    There should be a special hot seat in hell reserved for the engineer that signed off on the VW T4 engine bay. I have never encountered so many sharp corners and hard to access nuts and bolts in any car!
    Adelaide hills, SA
    Quote Originally Posted by Racemag View Post
    Then try to work on Alfas.
    Jun 2011
    Vic
    you need a second elbow on each arm?
    Jun 2012
    NSW
    or were they just practicing and getting warmed up for the T5 2.5 ?
    Mt Cotton
    Sorry to say I agree 110% some of the things I see in VW's and yes they are by far the worse for some unbelievable ideas . If you own a VW Golf 7 Never remove the grab handles in the roof lining it 's more fun to flog your self with a cat o nine tails . I cannot understand why one model VW has simple screws to hold the same thing to the body and in another a ridiculous system of suicidal clips which defy removal and require brand new expensive parts just to refit them . Yes I know that at the assembly line a clipped in part would be quicker but some poor sod will eventually have to work on it .
    Jun 2011
    Vic
    Did anyone ever have to refit the short crank bolts...460nm! 460! who the hell has a torque wrench that goes that high. Hell 160Nm + 180 deg required a 2m extension!
    Dec 2008
    Sydney/Canberra
    Did you replace the crank bolt?
    They're single-use, you know
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Mt Cotton
    Shhh now you tell him .
    Jun 2011
    Vic
    yep sure did, though getting the old one off was hell ona stick!
    I used a gates belt off ebay and bolt from VW. Belt is very noisy, just hope it's not the water pump as I replaced that 10,000km ago.
    I did discover that the engine had a incorrect thermostat fitted which may have contributed to the problems.
    Dec 2008
    Sydney/Canberra
    Perhaps its been over-tensioned?
    '01 Beetle 2.0
