Get it scanned and fixed. Could be detrimental to the DPF.
No point guessing.
Hi, my glow plug warning light has just started flashing. Could someone please tell me the possible causes and how to correct it. T5 2007 Transporter Four Motion. 2.5 diesel.
PROBLEM SOLVED. FAULTY BRAKE SWITCH.
No point guessing.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
2007 model.....DPF????
check your brake lights are working.
If not, replace/repair brake switch.
Known problem
Steve
04 T5
Get a fault scan mate. Without that it could be anything.
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
Could you please provide contact details to 0418 798 797.
I may ask the question? why would brake lights affect the glow plug lights . Seems like the more technology progresses the more weird things happen .
Numerous Mk1 Golf diesels
Yep...does double duty on the T4 diesels as a 'check engine' light. Which is kind of bizarre when the only time I've seen it flash is when the brake light switch has turned turtle
Could be worse I s'pose...it could just dump the entire driveline into 'limp home' mode instead. That'd be fun.![]()
