Results 1 to 10 of 12
Thread: Glowplug Light Flashing
    Jan 2012
    Alexandra Hills Qld
    Hi, my glow plug warning light has just started flashing. Could someone please tell me the possible causes and how to correct it. T5 2007 Transporter Four Motion. 2.5 diesel.
    PROBLEM SOLVED. FAULTY BRAKE SWITCH.
    Dec 2008
    Sydney/Canberra
    Get it scanned and fixed. Could be detrimental to the DPF.
    No point guessing.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    IN2VWS Guest
    2007 model.....DPF????
    Feb 2008
    Adelaide,Oz
    check your brake lights are working.
    If not, replace/repair brake switch.
    Known problem
    Steve
    04 T5
    Mar 2013
    Brisbane QLD
    Get a fault scan mate. Without that it could be anything.
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Jan 2012
    Alexandra Hills Qld
    Could you please provide contact details to 0418 798 797.
    Quote Originally Posted by Rebuild View Post
    Known problem
    Thats what it was on mine
    Mt Cotton
    I may ask the question? why would brake lights affect the glow plug lights . Seems like the more technology progresses the more weird things happen .
    May 2006
    Adelaide South Australia
    This is not something new, exactly the same on my '01 T4. VW just use the glow plug light for multiple uses.
    Numerous Mk1 Golf diesels
    Jun 2006
    with the dust and flies in western Victoria
    Quote Originally Posted by jets View Post
    Yep...does double duty on the T4 diesels as a 'check engine' light. Which is kind of bizarre when the only time I've seen it flash is when the brake light switch has turned turtle
    Could be worse I s'pose...it could just dump the entire driveline into 'limp home' mode instead. That'd be fun.
