Results 1 to 2 of 2
Thread: getting power to a dashcam
    Aug 2017
    Holsworthy, NSW
    Hi just wondering if there is an easy and elegant way to get power to a window mounted dash cam?
    Mine is t5.1 highline multivan.
    Is there suitable power supply inside the lights near the rear view mirror perhaps?
    Pacific Paradise QLD
    Quote Originally Posted by heyasam View Post
    Best way is from the fusebox with an addafuse DONT cut into circuits in a VW or you could be in a world of pain.
    Also is the camera q 12 or 5 volt one Makes a big difference.
    If its a 12v one get an addafuse and a spare ciggy socket and plug addafuse into fuse then attach the ciggy holder and plug original plug into it Do the same if is 5 v as the ciggy plug will have a stepdown in it.
    This gives you the idea of what to do
    Dash Cam Install Tutorial – Volkswagen MK7 Golf – AutoInstruct
    And this is the ciggy socket
    CIGARETTE LIGHTER INLine Socket | Jaycar Electronics
    If you cant solder buy this
    15A Cigarette Socket to 8mm Eye Terminal | Jaycar Electronics
    Addafuse Double Blade Fuse Socket Wire Tap | Jaycar Electronics
