Results 1 to 10 of 11
Thread: gearbox oil DSG7
merlot gearbox oil DSG7 17-08-2018, 12:29 PM
VW Convert Hi Russ, I'm pretty sure... 17-08-2018, 01:31 PM
merlot thanks george i thought it... 17-08-2018, 04:19 PM
Kombi Just bought a 2012 multivan... 03-09-2018, 08:49 PM
Umai Naa!! Can't go wrong with a euro... 03-09-2018, 09:01 PM
Kombi Thanks Umai, 60000km interval... 04-09-2018, 08:12 PM
Umai Naa!! Correct. Make sure you get... 04-09-2018, 09:03 PM
twistit What specific grade of oil... 20-09-2018, 12:44 PM
Umai Naa!! The engine, or the gearbox? ... 20-09-2018, 12:59 PM
twistit Where do you buy these... 20-09-2018, 01:07 PM
Umai Naa!! Tooley Imports will carry... 20-09-2018, 01:09 PM
    Aug 2018
    triabunna tasmania
    gearbox oil DSG7
    hi all
    prob been covered before but search didnt show
    i appreciate DCT oil in the DSG6 given wet clutches,but (why) do you need it in dry clutch box?
    i cant see why i cant get a quality gear oil from supercheap
    also am fitting different box,and this has 4motion takeoff (still a DSG7)
    if i decide to keep 4motion,does the above oil (DCT)need to be used
    was there a recall of VW DCT oil due to problems with mechatronic and high sulphur content
    thanks for any replies
    russ
    Jun 2007
    Quote Originally Posted by merlot View Post
    hi all
    russ
    Hi Russ,
    I'm pretty sure the 7 speed DSG in the Transporter is a DQ500 wet clutch transmission as distinct from the DQ200 dry clutch transmission used in Golfs, Polos etc. If I recall correctly, there was a recall of DQ200 dry clutch transmissions where the synthetic oil was replaced with mineral oil due to some sort of corrosion issue I believe. These two transmissions are chalk and cheese.
    George
    06 Jetta 2.0TFSI Killed by a Lexus!
    09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
    14 EOS 2.0 TSI has arrived!
    Aug 2018
    triabunna tasmania
    thanks george
    i thought it was a dg200
    i just had a look under,and its stamped OBT so DQ500
    ill be sure to use DCT oil
    Aug 2013
    Esperance
    Just bought a 2012 multivan with 110,00km, the service book shows transmission was done at 60,000km, is 60 interval recommended and what oil best for DSG7speed
    Thanks
    Dec 2008
    Sydney/Canberra
    Can't go wrong with a euro brand like Ravenol, Liqui Moly, or Febi.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Aug 2013
    Esperance
    Thanks Umai, 60000km interval recommended ?
    Dec 2008
    Sydney/Canberra
    Correct.
    Make sure you get a filter as well. It's different to the 6-speed, and may need to be ordered in.
    '01 Beetle 2.0
    Dec 2015
    sydney
    What specific grade of oil and filter should be used in a ‘15 DSG7 bi turbo transporter? There’s little to no info on the net...
    Dec 2008
    Sydney/Canberra
    Engine takes 504/507-spec 5W30.
    Gearbox takes approved DSG oil, equivelent to G052185A2.
    Filters, avoid Ryco garbage. Use genuine VW, or OEM like Hengst, Mahle, or Mann.
    '01 Beetle 2.0
    Dec 2015
    sydney
    Where do you buy these filters though? And what part number?
