Originally Posted by
merlot
hi all
prob been covered before but search didnt show
i appreciate DCT oil in the DSG6 given wet clutches,but (why) do you need it in dry clutch box?
i cant see why i cant get a quality gear oil from supercheap
also am fitting different box,and this has 4motion takeoff (still a DSG7)
if i decide to keep 4motion,does the above oil (DCT)need to be used
was there a recall of VW DCT oil due to problems with mechatronic and high sulphur content
thanks for any replies
russ
Hi Russ,
I'm pretty sure the 7 speed DSG in the Transporter is a DQ500 wet clutch transmission as distinct from the DQ200 dry clutch transmission used in Golfs, Polos etc. If I recall correctly, there was a recall of DQ200 dry clutch transmissions where the synthetic oil was replaced with mineral oil due to some sort of corrosion issue I believe. These two transmissions are chalk and cheese.
George
06 Jetta 2.0TFSI Killed by a Lexus!
09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
14 EOS 2.0 TSI has arrived!
