Results 1 to 10 of 11
Thread: Mysterious uneven idle
    Jun 2012
    MacMasters Beach
    My 2007 T5 4 motion is an ex ambulance with the slightly raised Bilstein suspension. It has only just clicked over 150k (i've owned it since 24k). It has recently developed an uneven idle. There does not appear to be any loss of power or increase in fuel use. The uneven running seems to disappear above idle. I've had the injectors and pump checked (fine). Nothing shows on scans. My mechanic suspects a worn camshaft he has heard reports of this starting to be a common fault. Has any one out there got any suggestions.
    Aug 2016
    NSW
    No..........but 150k isn't much.
    Get anything further yet?
    2018 Crafter Runner
    T5.1 6sp manual.
    Jun 2012
    MacMasters Beach
    Nothing yet, I've still got the slightly uneven idle but it doesn't seem to be getting any worse. My mechanic is doing a bit of research but it's not critical. Would like to solve it though.
    Feb 2008
    Adelaide,Oz
    Have you had it scanned for codes?
    Steve
    04 T5
    Jun 2007
    Melb.
    Quote Originally Posted by Jazzman View Post
    My previous T5 2007 had it's camshaft replaced. It became noticeable with the idle behaving as you described but more obvious was the sound, a deep knocking noise which even I at first thought was something heavy knocking against the chassis. At the time the van was getting worked hard, not as in thrashed around but doing heavy loads, towing, long runs and then lots of metro stop start. etc.. Sadly it got worse quickly once noticed. Occurred at 191,000km back in 2012 and I had all 4 disc rotors and pads replaced and full service plus camshaft replaced for around $8K...the reason I remember so well was I forgot my credit card and used the managers PC to make an EFT.
    EDIT: It was a known issue, maybe not common like DSG's etc...but the service staff certainly had repaired others and blamed on metal quality of the camshaft...hence why I was given a small discount.
    Mt Cotton
    I would add that the correct oil is paramount with that model and I think from others it would over time lead to camshaft troubles .
    Jun 2012
    MacMasters Beach
    Yes had the codes scanned and they showed nothing. I am not aware of any knocking from the camshaft. I think I will have it scanned by VW maybe my mechanics software is not sophisticated enough.
    Mt Cotton
    I don,t think their related but ours developed knocking noise and we suspected broken cam shaft , luckily it was a airconditioner compressor bearing that failed and in turn it broke the mounting due to vibration .Only a $1600 repair as VW would not replace the bearing worth $20 but I suppose it could have been worse .
    Aug 2016
    NSW
    I have a rattling noise coming from the aircon.
    I thought it was the serpentine belt tensioner making all the noise but changing it only helped a little.
    Then I noticed it went away when I engaged the aircon.
    Not sure what to do about it so far.
    2018 Crafter Runner
    T5.1 6sp manual.
    Mt Cotton
    Sounds like an air con problem as when the air is on the compressor is under load which might explain the noise .
