Results 1 to 8 of 8
Thread: Fuse box problems
    Dec 2008
    Perth, WA
    Fuse box problems
    Hi, can anyone help me, I just bought a -99 T4 2.5 Petrol at the auctions. Surprise, surprise, of course there are no manuals whatsoever, no owners manual, no nothing, fair enough, I believe the vans been well looked after service wise, it's an ex ambulance. My problem now though is that because of this, a lot of wiring has been reallocated to the ambulance "computer" such as indicators and lights, but wanting to get rid of all unnecessary stuff, I would like to make use of the original fuse box, but I have no idea as to which fuse is which. Short of measuring each wire up, which will take a lot of time as there is a lot of fuses for this van, I would find it a lot easier to just look at a sheet. So my question is : Does anybody out there have a fuse "sheet" that you could possibly scan and help me out with?
    Thanks in advance, or as they say in these kinds of forums: TIA.
    Swetech
    Camden, Sydney
    On the original fusebox, the connectors all only fit in one hole.
    They only physically fit in one space on the panel.
    How have they done the ambulance fusebox? Tapped into the main fusebox, or cut the connectors off?
    If its only spliced, you should be able to see how it used to be and put it back as it was. I do this a lot with aftermarket alarms.
    Good luck with the book, I`d get one off ebay uk.
    Dec 2008
    Perth, WA
    Yo Golf loon
    The wiring has been all "tapped", but not at the fusebox. That in itself is not so much of a problem, my problem now is more that there are a few pieces of equipment that are not working after I re-routed and re-terminated the cables, I know that I've made all the right fixes and that part is ok, it's just that since the system is now relying on the original fuse box and some of those fuses have been left out by the "ambulancing" mob, it'd make my life a lot easier if I had the print of fuse locations to be able to locate the correct fuse quicker when and if they blow.
    Now Adelaide!!!
    Here is a list of which fuse does what.
    And there amperage..
    And colour..
    Hope it might be of some help.
    Rob
    1, low beam left
    2, " " right
    3, number plate light
    4, rear wiper/washer
    5, windscreen wipers/washer
    6, blower
    7, tail & side lights right
    8, " " " left
    9, empty
    10, fog lights
    11, high beam left,
    12, " " right
    13, horn
    14, reversing light
    15, carburettor or engine-electronic
    16, warning lamps
    17, turn signals
    18, fuel pump
    19, radiator fan/air conditioner
    20, brake lights
    21, int & luggage compartment lights, clock, radio
    22, cig lighter
    ____________
    1 - 10a
    2 - 10a
    3 - 10a
    4 - 15a
    5 - 15a
    6 - 30a
    7 - 10a
    8 - 10a
    9 - Blank
    10 - 15a
    11 - 10a
    12 - 10a
    13 - 10a
    14 -10a
    15 - 10a
    16 - 15a
    17 - Blank
    18 - 20a
    19 - 10a
    20 - 10a
    21 - 15a
    22 - 10a
    ________
    5 Amp ORANGE
    10 Amp RED
    15 Amp BLUE
    20 Amp YELLOW
    25 Amp CLEAR
    30 Amp GREEN
    Rob
    May 2006
    Adelaide South Australia
    There may be something here that helps you.
    http://www.vwbooks.co.uk/t4.htm
    Numerous Mk1 Golf diesels
    Camden, Sydney
    It should also tell you which fuse does what on the back of the undertray / pocket that you remove to get at the fusebox
    Dec 2008
    Perth, WA
    Sweet, thanks mate
    Thanks a bunch, really needed that info, went around to the commercial VW sales and service today to get an owners "manual", but to no avail, couldn't supply me with one ! Re the undertray, nope, some clever (not) individual have removed the sticker (sheet), that's why I was in a bit of a pickle to start with, also realised today that the relay has been omitted, no tick tick sound when applying hazardlights. man, you have really been a great help !!!! I'll be printing the info on a sticker and glue it into the cover.
    Thank you again!
    And Jets, thanks for that link, I do need as much info as I can possibly get. I bought a "service manual" from Componline ? in Sydney the other day but the manual was a bit iffy to say the least.
    Thank you guys for your help.
    Swetech
    Jan 2007
    You could also try here:
    https://erwin.volkswagen.de
    Golf V TDI 2005 - SOLD
    Volvo C30 D5 - I've got a hat as well!
    Multivan Highline T5 TDI 4Motion 2005
    Hond Civic VTI 2001
