Results 1 to 3 of 3
Thread: Fuel smell - leak under the bonnet
    May 2012
    Adelaide Holden Hill
    Hi all,
    I performed a quick search and didn't find what I was wanting.
    To me this looks like the fuel lines and from other reading the one with the blue marker is the return.
    I am wondering if the flexible hose comes off?
    Dec 2008
    Sydney/Canberra
    The flexible rubber is swaged/crimped on.
    You can try and replace the hose clamp with a worm drive-type one, and see if the tighter fit stops the leak.
    Failing that, you might have to pull the whole fuel line out, and have Pirtek do a cut-and-shut on it with new hose.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    May 2012
    Thanks for your answer, i suspected that.
    I was hoping the leak was in an easy spot, alas when running I can see the small stream of fuel from the smaller hose.
    Looks like I need to replace the whole line.
    Is that a made to measure piece?
