M10 Spline.
You'll need a long breaker bar, or a pipe on a short one, to crack the caliper bolts (21mm) though.
The caliper slide bolts to get the pads out, are 9mm hex, from memory.
Hi all
Vw t5 2011 TDI 2.0
Multivan
Could anyone confirm for me what tool to use to remove the front discs (The single bolt that holds the discs on )
One video on web says a M10 spline, another says T10 torx?
I’m planing on doing pads & discs this weekend,
So haven’t taken wheel off yet, just want to get all tools required.
Thanks in advance
Rgds
Riche
M10 Spline.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Yep thought so thanks for reply
Just make sure you clean the backing part of where the disc bolts onto if there is any rust ensure its clean , as I discovered a couple of sets ago that small amount of rust can cause the disc to sit incorrectly and cause vibration when braking .
Yeah will dothanks for that
So all went well on the disc & pad change,
I also undone the two front brake lines to take calipers off & gave really good clean & a paint.
So of course might as well do a brake fluid flush & bleed. Seems I have some air still in the lines somewhere cuz the pedal will very very slowly keep going down, brakes work fine though.
After reading a bit on the web , I’m not sure if I need to VCDS the abs module to cycle it, thing is I don’t have vag-com or software like this to do it.
Only have the mobile OBDCarDoctor etc.
the other thing I was going to try was to pressure bleed the brakes, as we were doing it old fashioned way , pumping pedal into bottle with a bit of new fluid in the bottle to start with ??
Anyone have any thoughts??
Cheers all
Riche.
Vw t5 2011 tdi 2.0
From the old days, a sinking pedal used to be a sign of failing seals in the master cylinder as the fluid would under pressure leak back past the seals causing the fluid to return to the reservoir . Nice paint work though !
There is a good reason why Volkswagen requires brake fluid to be pressure bled. You can’t get all the contaminated brake fluid out of the ABS pump by pushing the brake pedal like in the old days.
Ok thanks for reply guys, will try a pressure bleed in the next few days & see how that goes
Cheers all
This is similar to the pressure bleeder I use but mine is model 0100 European model. I purchased it several years ago through Amazon for around US$50 + freight. Amazon no longer will post to Aust. & I believe GST is now added. Works well but I use mine dry to eliminate messy cleaning, but you need to watch the res. level.
Tool: Motive Products Standard Brake Bleeder with Universal Adapter | eBay
Numerous Mk1 Golf diesels
