Frequency
Neither fm or am works on my new ‘12 multi, any suggestions before I pull unit out to inspect wires at the back ?
Check to see if its a genuine VW RNS series or a copy cat aftermarket one , there are lots of aftermarket ones that fit the same aperture . A lot of the aftermarket ones once fitted have poor AM and FM reception due to the factory ones being sort of tuned to the cars own anntenne . I have changed both of ours with aftermarket and the AM FM was crap , so I fitted an external roof mount which improved reception . Since then I have discovered the joy of online internet radio which I then bluetooth to the head unit from my phone , as long as you have a reasonable download allowance it is really good . One last thing some of the early VW vans had the antennae built into the windscreen so if it has been replaced with a cheaper one there would be no reception at all. On later series VW mounted antennae inside the front door external mirrors using diversity technology , that means the anntenae will switch from one mirror to the other depending on which one picks up the strongest signal from the station . Last one the VW antennae are powered through the CAN bus system , and aftermarket head units don,t seem to have the capability to power up the anntenae . Some of the installation centres have awork around to power up the VW antennae . Removing the head unit is a piece of cake unclip the tray above the head unit by pulling it upwards just over the top when the tray is removed there are two torx screws to remove , then pull the front facia off and there will be 2 torx screws on the outer side of the head unit . Just pull it out and all you need is right there , check to see if the antennae plug is correctly fitted .
Thanks Howard, looks stock standard unit, but who knows, good idea to use phone, guess no more data than Apple Music app
Personally over the years as I get older and grumpier I find the announcers on most commercial radio stations just aggravate the hell out of me with their inane stupid humour , too many adds and idiots trying to be funny . But now I have discoverd an online radio network out of Europe that plays my kind of music and does not have live announcers and only the odd station promo . Have you removed the unit to check brand and connections ?
Amen, I must be getting older and grumpier too, only thing on radio I care to listen to is abc conversation hour, but still it’s a German car so everything must work, pedantic me, I’m hoping to pull unit out tomorrow, will post
Haven’t got the the radio yet Howard, but RN working fine through phone thanks
- You may not post replies
- You may not edit your posts
Forum Rules
