T3 DIY Coolant Change
Hi
After much delay finally have time to do some overdue maint on my T3 ,2.1 auto
At present Im replacing my Master Cyliinder. As the van is now off the road for a day or two ,my next urgent job is DIY Coolant change.
Im a little confused here especially when refering to the workshop manuel.
To 'drain' my old coolant Im under the impression that all I have to do is :
- Open the expansion tank cap
- Drain the coolant at the drain plug on both cylinder heads.
Q.... Would I need to do anything else or should this suffice.
Also: While draining should the vehicle be level or better front end higher.
PS I do intend to use G12+ coolant.
Any help appreciated.
ajp
- You may not post replies
- You may not edit your posts
Forum Rules
