Firstly, welcome!Seems like you love your van. Petrol or diesel?
Firstly check the oil level in the gearbox. Then the mounts because when under torque in 1st the whole drive unit may be moving. I seem to remember this occurring with another forum member so it may be worth doing a search to read the storyOf they're OK check the drive shafts for rubbing as they are under the most strain pulling away in a low gear. I reckon if you had internal gearbox problems the signs would be much worse.
So is it doing it on deceleration to? Now I'm confused.The slower i go the worse it sounds once you pick up speed it kind of fades every other gear is great.![]()
That's the last and most expensive resort (although rebuilding your present one could be dearer!)I may need a replacement box?
I also need a good drivers seat? anyone?![]()
