Results 1 to 8 of 8
Thread: First gear noises
    T4er Guest
    First gear noises
    Hi,All I am now the proud owner of an excelent 99 model t4 never driven a van like it. I am now converted.However I seem to have a problem with the gearbox In first gear it makes a strange sound like as if a sproket is rubbing on something or buggered syncro. The slower i go the worse it sounds once you pick up speed it kind of fades every other gear is great.I may need a replacement box?I also need a good drivers seat? anyone?
    brackie Guest
    Simple checks?
    Firstly, welcome! Seems like you love your van. Petrol or diesel?
    Quote Originally Posted by T4er View Post
    Firstly check the oil level in the gearbox. Then the mounts because when under torque in 1st the whole drive unit may be moving. I seem to remember this occurring with another forum member so it may be worth doing a search to read the story Of they're OK check the drive shafts for rubbing as they are under the most strain pulling away in a low gear. I reckon if you had internal gearbox problems the signs would be much worse.
    So is it doing it on deceleration to? Now I'm confused.
    That's the last and most expensive resort (although rebuilding your present one could be dearer!)
    T4er Guest
    I'll go throug & do relevent checks,when I say the slower I go the worse it sounds I mean as I pick up speed & increase torque In first gear,the noise gets noticeably quieter.However thanx for the reply
    Jan 2007
    South Australia
    Welcome T4er
    Quick Q - how did you find this forum ?
    - Ben
    1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
    2008 Jetta 2.0L FSI
    brackie Guest
    Expert opinion
    It's very difficult to diagnose problem noises over the internet. Best bet is to go to a recognised VW workshop and let someone experienced listen to it. Where are you? If you post your location we may be able to help.
    T4er Guest
    Bumped into it
    T4er Guest
    I am in Shellharbour south of the gong
    Jul 2005
    Check the gearbox level, top up with the appropriate oil, it is full synthetic.
    Try some Nulon gear oil also, as I use in mine, it does make a difference.
    Maris
