Hi SSG the light bar is only activated when the high beam is on , believe me if you were to have the light bar on with normal lights you would find yourself on the receiving end of an angry mob of blinded drivers !! . This is the one we have on both our T5s the early T5 is easier to fit as the grill is different on the later T5.1
19 6" Inch 126W Cree LED Work Lamp Combo BAR Light Truck Boat Offroad 4WD Lamp | eBay It takes around two hours to fit wiring is easy just fit a 40amp relay and connect to the high beam trigger wire and that's it .
