Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 59
Thread: Engine replacement.
  1. #21
    Dec 2008
    Sydney/Canberra
    Passat Alltrack motor would be the same base engine, if not very similar.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  2. #22
    Feb 2009
    NSW
    What is the engine code?
    Sent from my Pixel 2 using Tapatalk
  3. #23
    Feb 2009
    NSW
    What about swapping the engine and box out. Is the box connected to the rear Diff or does the drive go through a separate transfer case (???) type of setup?
  4. #24
    Feb 2009
    NSW
    Stop leak hasn't worked. Now losing oil and coolant...
    Anyone know of a cheap rs4 engine lying around???
  5. #25
    Adelaide hills, SA
    Did you try JB Weld PermOseal? Seals a lot of coolant leaks almost immediately.
    Available from Bursons or ebay.
  6. #26
    Feb 2009
    NSW
    No. That's the next stop. But it's getting Mayo under the cap so I'm thinking it's much worse.
  7. #27
    Feb 2009
    NSW
    Is there a site that tells you the compatibility between engines and boxes?
  8. #28
    Adelaide hills, SA
    Flush the cooling system, using good radiator flush, refill with the fresh coolant and put 1 PermOseal in the reservoir once warmed up and run engine for 30 minutes after thermostat opened.
  9. #29
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by ozgti View Post
    Just tried looking into this now.
    Part numbers are all over the place, with regards to what is compatible, and what isn't. Part numbers for long motors are all different between Amarok, T5GP, and Passat, even though in theory they're all pretty much the same generation TDICR motor.
    Wreckers over here are taking the pi$$ on prices. Can get a rebuilt one out of the UK, for circa $5K. A Used one here, is twice that amount, and you'd still have to pay someone to swap the whole lot over.
    '01 Beetle 2.0
  10. #30
    Aug 2016
    NSW
    Yeah......you can see why the Pommies get a shock when they come over and buy one to go around Australia and are used to the costs over there.
    2018 Crafter Runner
    T5.1 6sp manual.
