Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Engine cover on T5 or not??
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by IN2VWS View Post
    Err....no they didn't. Work vans, Crewvans etc. did not get them, never did. They were always on the Multivans.
    My '07 crewvan didn't have one, nor did 2 other '07 crewvans nearby. I had to buy one for my van. These were all 1.9l motors. Maybe the smaller motors didn't get them.
    My apologies. When I submitted the post, I started to wonder if the 1.9s came with it. Thanks for confirming it, though
    Quote Originally Posted by MultiplexMan View Post
    Theoretically should get slightly better fuel consumption by presenting a clean profile to the air stream.
    I like your thinking!
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Mar 2008
    Actually not on all Multivans either. My 2008 Comfortline purchased new, did not have one, and there are no bolt holes in the correct location to put one on.
    Regards,
    Scott
    Jul 2011
    Westbrook, Queensland.
    Yes my 05 Tdi Dual Cab has one, I am going to make one from structural alloy beefed up a bit for off-road protection. For those that don't know the Tdi's have sound reduction covers on the sump and the camshaft/rocker cover.
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by Silver Caravelle View Post
    Regards,
    Scott
    That's odd.
    Even the ones that don't, still have the thread-serts (Riv-nuts) in the subframe.
    '01 Beetle 2.0
    Mar 2008
    Quote Originally Posted by Umai Naa!! View Post
    That's odd.
    May be for some of the bolt holes, but not all. They are located for the plastic cover on the outer edge of the engine bay Where the bonnet lock lines up, and the plastic battery cover (about 6 of those plastic screws in all). There are even two extra holes for this but no corresponding hole in the subframe. I recall there was some discussion about this on the Brickyard forum a year or two back. When I purchased the vehicle I quizzed the dealer. At the time they were not equipped with full engine covers. Perhaps the Highlines were? But certainly earlier T5s were. I even looked at a lot of new Multivan Comfortlines at the time and at different dealers, also on Carsales and none of then had full engine covers.
    Dec 2008
    Sydney/Canberra
    Oh no, no. We're referring to the big plastic belly pan undernieth
    '01 Beetle 2.0
    Mar 2008
    I am an idiot!! Yes I have the underneath cover.
    Hopefully the other information is still usefull...
    Cheers, Scott
    Mt Cotton
    Seems a bit inconsistent to me that VW have them on some and not others makes you wonder why ? our two T5,s have them sons T4 has a steel one .
    Jul 2007
    @Sunny43.5 - the answer is simple, cost.
    VWA can program a build but each variation/revision impacts the cost. Sometimes we get lucky. If the person responsible at VWA can spend the time and has the expertise, they can mix and match between construction stations and build modules to get the most vehicle for a target price.
    eg. If you have the finger on the pulse, you may hear of a cancelled fleet order for the UK. It may include height adjustable headlights for a Transporter. You may grab those for your order at internal discount.
    This has to align with marketing. If height adjustable seats are a better "sell" than undertrays - we lose the undertrays...
    As to plastic versus steel undertrays - cost and actual use. Out of the > 1,000,000 T5 (June 2009) T5 manufactured, exactly what percentage actually go off road? It would be nice if VW offered the option, but unless there is significant customer request, the factory leaves it up to third parties like Seikel.
    Jul 2005
    Newcastle, NSW
    I do have one but don't run it. I believe that it will aid in cooling the transmission as well.
