Never done it myself, but the local kids got mine off with a screwdriver a few years ago.
Has any one got any advice on removing the front emblem on a 2011 transporter?
I just got mine stone chipped so ordered another from the dealer, I am hoping to Remove the old one without breaking it.
Sent from my GT-N7000 using Tapatalk 2
2011 T5 4MOTION Duel Cab Optioned up.
If you have a heat gun or can borrow one it will do the trick. just dont get it too close. put some heat into the area and then lever if off.
or a hair dryer can help just depends on the glue strenght and how long it has been there. if you can remove the grill and heat from the back that would be because if you heat to much and it starts to fry you wont see it from the other side. As long as you dont stick it right on top for ten minutes it should not melt.
Just check behind the badge to make sure there are no screws holding it on from behind. im not sure about your model but some can be screw on not glue or tape so better to be on the safe side and check.
Ask the dealer for an exploded diagram picture when you collect your new one.
He can print you a screen shot so you can see how things work.
Rob
