Originally Posted by
Kombi
t’s been a while since I researched this problem, plenty of information if you join the fb group.
From memory the aluminium particles contaminates the engine oil in the cooler part.
The combination egr & cooler & filter was replaced as a complete unit in my case.
I was told blocking egr without removing dpf will cause problems, I tried it anyway, after about 5000km mine went into unregenerable limp mode with blocked dpf, my understanding is that you need the egr to get the high temperature needed to burn the soot in dpf.
