Results 1 to 10 of 18
Thread: ECU replacement cost?
    Jul 2010
    Geelong West, VIC
    So before I tackle the stat problem another one has cropped up...
    Flashing glow plugs and "Engine Workshop!" error on dash this morning. Engine turns over but won't start. Call the RACV - no fault codes pop up on the VAGCOM. After checking the fuse boxes - fuses SC26 and SC33 also blown.
    Looks like it is a failed ECU which is apparently a common failing part for the 2.5TDI. Prior to this, it had been intermittently difficult to start and had other intermittent issues with the central locking which is also an indicator of the above.
    My question - has anyone had to replace/repair the ECU and approx how much was it?
    05 T5 Multivan 2.5 TDI
    Sep 2012
    Dec 2008
    Sydney/Canberra
    Have a look under the passenger's seat at the multifunction connectors, and see if there's anything foreign in the spare plugs.
    All of them are pretty much live, and some of them are inputs and outputs to/from the ECU.
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by Brientim View Post
    ECU - Engine Control Unit, in this case.
    Not the same car, but this might give you an indication of cost - my friend had to replace the ECU in his VW Golf Mk5 GTI and it was about $3,500 all up.
    The ECU itself was around $2,200 and the rest was 'labour charges'.
    Jul 2010
    Geelong West, VIC
    I looked under both front seats. Only a bit of dust and dog hair which i vacuumed up. Still no joy.... and now the van is locking itself sometimes but not all the time.
    Jul 2010
    Geelong West, VIC
    Does anybody know if you can remap the ECU while its faulty? I am thinking of asking one of those performance tuning places. They claim they can give you more power and make it more economical at the same time
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by minniemousey View Post
    I don't think it's an ECU fault.
    I'd be looking at an electrical fault.
    Jul 2010
    Geelong West, VIC
    The van has been hard to start sometimes, it does nothing when you turn the key. Then after between 2 & 6 times it starts. The central locking doesn't always work as it should. Sometimes 1 or the other sliding door won't unlock/lock. Internal lights sometimes turn off/on randomly. The 2 blown fuses noticed today, no 26 & 33 in the bottom panel under bottle holder. Nothing else seemed to be not working with the blown fuses and i'm not sure what fuse card to go by to tell me what they are. 1 card says 26 is a low beam & 33 is radio, radio was definitely working.The other "option" card 26 has a T & a symbol of 12v inside a rectangle and circle and 33 has a T. This van is very frustrating, when it's good, it's great & when it's not it's expensive....
    Quote Originally Posted by Umai Naa!! View Post
    If the engine runs ever, I don't really see the ECU being a problem.
